Digital I/O
DAQmxBase Error -1073807346 on USB6501
The full error I get is
DAQmxBase Error -1073807346: Refnum to Session in Fusion.WriteThenRead.vi->Fusion.DIO_Immediate.read.vi->DAQmxBase Write Fusion(Digital 1D U8 NChan 1Samp).vi:5->DAQmxBase Write (Digital 2D U32 NChan NSamp).vi:2->DAQmxBaseWriteDigitalU32.vi->DAQmxBaseWriteDigitalU32.vi.ProxyCaller
What I am trying to do is write a Python daemon program to get around
the ~20 sec time it takes to loads the libs and dlls. So as a test I want the daemon
to write an incrementing value every 10 seconds to the port0
the code looks like
    write_byte(121) ###### It works fine here. In fact if I don't write here before the main loop the main loop crashes.
_constants = ['count']
count = 55
def main(count):
    """ A demo daemon main routine, write a datestamp to
        /tmp/daemon-log every 10 seconds.
    import time
    #count = 0
    f = open("/Users/daemon-log", "w")
    while 1:
        f.write('%d %s\t' % (count, time.ctime(time.time())) )
        f.write('%s\n' % sys.platform)
        f.flush()
        time.sleep(10)
        #print "\a"
        count += 1
        #if count ==1:
        write_byte(count) ######### This is where I get the error or crash if I don't write_byte above
So I am a lot naive about  writing a daemon program so I don't quite understand exactly what I am doing
but the Python write_byte routine does work. Any thoughts , pointers or references would be greatly appreciated.
Thanks much,
Doug Taylor
(4,232 Views)
I should have mentioned that this is on MacOSX. Thanks,
Doug
(4,231 Views)
Hi Doug,
It sounds like you are trying to eliminate the load delay. There is no way to eliminate this because the LabVIEW Run-Time Engine is being loaded. I recommend going to back to a language that you are more comfortable programming with and using some example programs. The DAQmx Base text based examples on the Mac are located in Applications >> National Instruments >> NI-DAQmx Base >> Examples. The LabVIEW Examples are in the LabVIEW Folder. I hope that you find this information helpful.
Hal L.
(4,219 Views)
