Digital I/O
DAQmxReadDigitalLines Parameter
I want use the Function DAQmxReadDigitalLines, but I dont know about the Parameters and can´t find a suitable topic in help.
I set the Parameter in this order:
DAQmxReadDigitalLines (th_in, DAQmx_Val_Auto, 10.0, DAQmx_Val_GroupByChannel, data, 1, NULL, NULL, 0);
data is an array[8] of uInt8.
The problem is that the Function doesn´t write the Input Lines into the data array.
It will be nice if someone could explain the correctly use of the parameters to me.
Thank you
(4,638 Views)
I´ve found out the solution.
The Array_Size_In_Bytes must be 8 and not 1.
DAQmxReadDigitalLines (th_in, DAQmx_Val_Auto, 10.0, DAQmx_Val_GroupByChannel, data, 8, NULL, NULL, 0);
These are the correct Parameters.
(4,635 Views)
