Digital I/O
DIG_Block_Out timeout error
hi,
I've been trying to use double-buffered Pattern I/O on the NI6534, I followed all the steps in the flowcharts and the sample code, but when I tried it myself, it would always give me error -10800 on the DIG_Block_Out stage (which is a timeout error). Why does this happen? It shouldn't be waiting for a signal since its not handshaking I/O...
any suggestions or clues?
thanks.
(3,164 Views)
Have you tried running the DAQdoubleBuf example in CVI? The example is located in C:\Program Files\National Instruments\CVI71\samples\daq\Ai
Let me know what behavior you observe when you do this.
Jaideep J
National Instruments Corp.
(3,146 Views)
