Digital I/O
DIG_Prt_Status always returns 4 when port A is configured for bidirectional handshaking
When I configure port A on a LABPC-1200 to be bi-directional and try to use DIG_Prt_Status to check whether I can write to the output latch it always indicates the latch is empty by returning a 4. If I write to port A, OBFA goes active, DIG_Prt_Status still returns a 4. If I use REG_Level_Read on port C at this point it port C show OBFA is active. What gives?
I am going to use REG_Level_Read to get around this, but it's in the obsolete section of the header file and I'm afraid it will disappear leaving me with no way to handle this situation.
(3,359 Views)
kflynn,
The following two Knowledge Bases should explain what you are seeing. Especially take note of the last paragraph of the first KB:
http://digital.ni.com/public.nsf/websearch/F865C1157622C9DE8625648B00782CDA?OpenDocument
http://digital.ni.com/public.nsf/websearch/92582BD25EE97F8D85256442005968C9?OpenDocument
Ames
Applications Engineering
(3,359 Views)
If I set PORT A of a LabPC to OUTPUT and HANDSHAKING then call DIG_Prt_Status I will get a 1 in the handshakeStatus variable indicating that it is safe to write to port A. If I then write to port A and repeat the call to DIG_Prt_Status I will get a 0 in the handshakeStatus variable indicating that the data has not been ACK'ed and therfore it is not safe to write to port A.
If I set PORT A of a LabPC to INPUT and HANDSHAKING then call DIG_Prt_Status I will get a 0 in the handshakeStatus variable indicating that no dat has been STB'ed in.
On the other hand if I change the setting to BIDIRECTIONAL and HANDSHAKING, DIG_Prt_Status will return a 4 no matter what the state of the port is.
I have to use REG_Level_Read to get the value of port C and test the
OBFA and IBFA bits to check the status of port A. My only worry is that REG_Level_Read and _Write are listed in the obsolete section of the header file and may disappear on me.
(3,359 Views)
