Digital I/O
DIO 96 Interrupts
I have configured my DIO 96 for Mode 1 Stobbed input per the example on page B-32. Will a signal on any bit of port A cause an interrupt? If not, what input pins do I use? To acknowledge the interrupt, is the only thing I need to do is write to the Interrupt Clear register? Do I reset any values in the configuration register after the interrupt?
Message 1 of 1
(3,833 Views)
