Digital I/O
DIO DAQ vi that can perform write and read measurements using binary data saved in a file
HI Christina
Thanks very much for the state machine VI and from the looks of things i should be able to modify it to suit my use, but some of the functions didn't open (missing) with LabVIEW 8.6 and 2009, thay have ? while some have broken lines and there were lots of syntax errors, thus i couldn't get it to run to view how it executes.  I don't know if you can fix that for me. Please.
Rgds
Paul
Message 11 of 20
(2,075 Views)
HI Christina
Thanks very much for the state machine VI and from the looks of things i should be able to modify it to suit my use, but some of the functions didn't open (missing) when i did open with LabVIEW 8.6 and 2009 demo versions, thay have ? while some have broken lines and there were lots of syntax errors like data type conflicts, thus i couldn't get it to run to view how it executes.
Please, i'll be grateful if you can fix the errors for me maybe you did it with an earlier LabVIEW version.
Rgds
Paul
Message 12 of 20
(2,075 Views)
Paul,
It opens with no errors in LabVIEW 2009 on my computer.  What VIs are missing?
-Christina
Message 13 of 20
(2,065 Views)
Hi Christina
Thanks for the response, please see attached file for what VIs are missing.
Rgds
Paul
Message 14 of 20
(2,046 Views)
Paul,
It looks to me like you don't have any of the DAQmx VIs.  Do you have DAQmx installed?
Sincerely,
Jason Daming
http://www.ni.com/support
Message 15 of 20
(2,028 Views)
Hi JD
I had NI-DAQmx version 8.8 installed on my machine which works with LabVIEW version 8.5, 8.6 and (8.9 not so sure), infact I have been using it for other simulations that i did with labVIEW version 8.6 and it works well. I don't know if it is possible to convert the state machine VI  to labVIEW 8.6, maybe it should work.
Rgds
Paul
Message 16 of 20
(2,022 Views)
Paul,
I have used the File»Save for Previous version tool to convert this to 8.6 hopefully it works for you!
Sincerely,
Jason Daming
Message 17 of 20
(2,004 Views)
Hi JD
I'm still having same loading error, i can't open the VI you converted to LAbVIEW ver 8.6.
Please see attached file for details. I just install the latest version if DAQmx (NI DAQmx Version 8.9.5).
You can even see MAX short cut on my desktop. I really don't know what is wrong.If i have some free time i'll re-install all the softwares i take it from there.
I appreciate the support.
Rgds
Paul
Message 18 of 20
(1,982 Views)
Hi JD
Rgds
Paul
Message 19 of 20
(1,981 Views)
You are not loading the correct files. The last ones posted by Jason is in ver 8.6.
Message Edited by Dennis Knutson on 10-13-2009 08:23 AM
Message 20 of 20
(1,972 Views)
