Digital I/O
DIO pin 0 not working on SCB-68A
I'm using a SCB-68A connected to a PXIe-7858R, and pin DIO 0 is not outputting any voltage.
All the other digital and analog pins are working fine.
How can I troubleshoot this problem?
(363 Views)
PXIe-7858 has two connectors. Try the other connector to isolate if the fault is coming from the module or the terminal block. You might want to do the swap test on the SHC cable as well.
https://tmesystems.net/
(344 Views)
Thanks for the suggestion, I'll have a chance to try it next week.
One more thing to mention, I have a SCB-68 HSDIO plugged in to the other connector and all of those DIO pins are working.
(324 Views)
