Digital I/O
Data Acquisition using PCI DAS 1002
I have a PCI DAS 1002 board. I am using VB to control it. Any idea if this board supports simple data acquisition?
Specifically, I want to make it read samples from data sampled by another clock. How do I synchronize/make DIN trigger at definite times corresponding to the edges of a clk?
Here is my test setup:
DOUT (DAS) provides CLK ( a sequence of 1 and 0 written using ULDO01)
My chip generates SCANOUT ( a sequence looking something like 1101010… synchronized to the positive edge of CLK).
I want to sample this SCANOUT using falling edge of CLK. ScanProblem.bmp illustrates it.
I have been using the UL library that came with the CD. Of several others, I tried the VBWIN file called CInScan01 but it gave the error as attached.
Pulkit
(4,056 Views)
Not only did you rudely attach bmp files renamed to jpg to get around the ban Smiley Mad, you posted to an NI board asking about a device from Measurement Computing. I would suggest you ask their support.
(4,049 Views)
