Digital I/O
Deadtime of Ni9402 input / output module
Im using a NI system where the digital output from a photomultiplyer tube is collected by a Ni9402 input / output module.
The photomoltiplyer tube itself has a deadtime but what I want to know is, if I can expect any deadtime from the NI components of this system. Does the Ni9402 has a deadtime for example ?.
Erik Jørgensen
(2,250 Views)
Hi erikbj,
You can access the datasheet for the 9402 at the link below:
NI 9402 Datasheet - National Instruments
http://www.ni.com/pdf/manuals/374614a_02.pdf
Jiwhan S.
Technical Support Engineer
(2,190 Views)
Thanks for the answer.
I am not very experienced in electrical engineering or in reading datasheets. So I dont know which one of the parameters listed in the datasheet which is the deadtime. And if it is a non-paralyzable deadtime or paralyzable deadtime (how should i model it) ?.
Erik
(2,183 Views)
