Ok, I see what your implying - so my custom cable gets broken down into its 15 constituent connections, leading into the BOB. Where I am falling down is with regards talking with this BOB - if the stepper motor is expecting serial coms on 15 pins, and my PC only has 9 pin serial connections, then even with the breakout box in-between, is there not an obvious disparity between the 15 pins on the motor and the 9 pins on the PC?
Or am I missing something painfully obvious?
Stepper Motor --- via DB15 RS485 serial -----> Breakout Box ----------> 9 Pin Rs485 PCI card
