Digital I/O
Delayed acquisition after start trigger on 6542
Hi all,
I'm trying to acquire a single digital waveform with a start trigger by using a PXI 6542 board.
The trigger I can use arrives 30 msec before my data burst (data burst width = 50 msec).
My sampling rate is high and my on board memory is low.
I need to sample my channel  at least 20 msec after the trigger.
How can I do that?
Thank you
Federico
(4,197 Views)
I had to do something similar a few days ago, with different hardware. You can configure delayed triggered acquisition using DAQmx. What I did was add Start.Delay property to DAQmx Start Trigger (Digital Edge).VI, see attached. You can set the delay in clock cycles or seconds. Note that you can not have a zero delay (took me some work to realize this), it must be at least 2 clock ticks.
(3,984 Views)
Hi guys,
The 6542 actually uses our HSDIO driver, so it does not have the same properties available that a DAQmx device would.
Unfortunately, the Data Delay property of HSDIO only allows for fractional sample clock delays (you cannot delay for nearly long enough).  A couple solutions I can think of that might work out for you:
1)  Trigger the acquisition off of your data rather than the trigger signal (you can use a reference trigger to acquire pre-trigger samples).  If there is a known signal on your lines you could try a Pattern Match Reference trigger.
2)  Pull samples off of the card as they are coming in so you do not run out of on-board memory.  You might want to check out the following streaming example: NI-HSDIO Stream to Disk
Best Regards,
John
John Passiak
(3,967 Views)
Hi Frederico,
How many channels are you acquiring on?  And are you acquiring using onboard clock or are you using Strobe?
Keith Shapiro
National Instruments R&D
(3,957 Views)
