Digital I/O
Detect 2 ms changes on USB-6509
Is it possible to use the USB-6509 to detect and read digital changes for 50+ channels. And the changes could be as small as only 2 milliseconds wide?
My first idea was to use the Change Detection feature of the 6509 to trigger a read DIO-event.
The data read could then be used to indicate which IO-port changed.
An alternate solution could be to poll the DIO continuously and detect the changes through software.
Although this would require a lot more processing. What data rates would be possible over USB?
Is this even possible over the USB-interface or do I need a faster interface, like the PCI?
JR
(4,062 Views)
You need to use a high speed DIO card or go with an FPGA card.  Personally, I would use the PCI-7813R.  It does require LabVIEW FPGA to program though.
(4,059 Views)
Thanks for your input!
I'll look into this.
(4,056 Views)
