Digital I/O
Difference between PCI-6514 and PCI-6515
What is the difference between "source" output in the PCI-6514 and "sink" output in the PCI-6515? Does it matter? All I need to do is open or close a 10mA current-limited circuit.
(4,045 Views)
Hi RJE,
The difference between a source and a sink output is whether it provides a ground or voltage source. So, depending on your circuit, if you need a ground then select the 6515 for its sink output, and if you need a voltage source use the 6514.
Here is a good knowledgebase on the topic.
Understanding sourcing and sinking
Hope this helps!
Jeremy L.
Jeremy L.
(4,044 Views)
