Digital I/O
Differential measurements on NI9025
I am trying to measure a differential voltage across a FET, FET is operated at 48V but the differential voltage will be less than 1V.
Can I configure NI9205 as differential voltage measurement
(1,750 Views)
Yes, it can work in differential or single-ended mode.
(1,707 Views)
You would be violating the max spec for each AI channel by having a Common Mode of 48V.
Santhosh
Soliton Technologies
(1,688 Views)
