Digital I/O
Digital I/O Handshaking with DAQmx using VB.NET
I am new to both Visual Basic and using the DAQmx driver. I want to output a vector N times and input the results to test against expected values at as high a rate as possible. I think I want to load my initial vector into the onboard memory once and then just reread it using a handshaking protocol with one port as an output and one as an input.
It seems like this example: http://sine.ni.com/apps/utf8/niepd_web_display.display_epd4?p_guid=B45EACE3EDC356A4E034080020E74861 would get me started, but it is geared towards VB6.0 and uses Traditional DAQ (Legacy). Can anybody pass on a suggestion or point me to a more up to date example? Any help would be appreciated. I am trying to get up and running on this. Thanks.
(4,329 Views)
Hi Max,
You should be able to find a lot of DAQmx Digital I/O examples in the following path:
C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C
Not too many of them are geared specifically for handshaking, but it should give you a good idea how it all works in DAQmx.  Then you can do all the specifics like make a finite output, read back near the max rate for your board, etc.
If you need any extra help, make sure to let us know what hardware you are using.
(4,316 Views)
I am using the PCI-6534 with VB.NET and attempting to utilize the DAQmx. I am new to all of the above. Do you know of any more direct examples or could you give me some guidelines for converting the code over? Thanks.
(4,299 Views)
Max,
We also have some VB.NET specific examples that I recommend taking a look at.  If you have Measurement Studio, some examples should be installed by default in the C:\Program Files\National Instruments\MeasurementStudioVS2003\DotNET\Examples directory.  There are also many examples posted online, which you can search for through the Example Code Library.  I found one example to get you started:
DAQmx - Continuous Read Digital Channel in Burst Mode - LabVIEW - CVI - ANSI C - VB.NET
I hope this helps!
Justin M.
(4,287 Views)
Thanks for the referral to that code. I think I understand the basics of it but I am having problems implementing a reader and writer at the same time.
I am trying to have the reader input its data on the falling edge of the clock and the writer output on the rising edge. These are just sample clock settings I believe, I encounter problems when I try to get them to occur at the same time. I have thought of a few ways that might work but I was just looking for a recommendation and maybe some clarifications on which are more feasible for a write that loops N times.
So here are what I've thought about/tried implementing:
-assign the reader to autostart and let the writer run with an async callback. in the async callback, save the read values to a file and then start the read again, incrementing a variable until the N loops is reached
-have the reader and writer in separate async callbacks, but might the reader lose some samples when saving to the file?
-have both run in the background using a background worker with a large buffer size of (number of samples)*N [which will likely exceed the 2x32MB onboard buffers] and have the reader loop its data and use a counter to tell it to stop [not sure how to implement a counter on a continuous write]
let me knowif any of thse are feasible or if you have any other suggestions...or if i am unclear. thanks.
(4,253 Views)
