Digital I/O
Digital Inputs
Hi I'm not sure if I am confused but what I would like to know is if I can connect a MLX90614 directly to my USB 6225 DAQ using labveiw.
http://docs-europe.electrocomponents.com/webdocs/0db7/0900766b80db745c.pdf
(3,300 Views)
Hi Alexanderr20,
It looks like you can use the 6225 with PWM. However, the way this sensor uses the PWM method is somewhat unusual, I would recommend using the USB-8451 with I^2C instead.
I hope this helps.
Josh L.
(3,279 Views)
