Digital I/O
Digital_Mode_ConfigInterface sends out Error 10403
I ran into Error 10403 on my LabVIEW application while configuring PCI-6533 (PCI-DIO-32HS) with DIO Config.vi in vi.lib\Daq\digital.llb. The strange is that an example (Buffered Pattern Input.vi), I believe, shipped from NI works on my DAQ/LabVIEW environment however same part of the example VI implemented on my application doesn't work - Definitely same variables selected for both example only ant it on my application - . As I did trobleshooting, I found that Call Library Function Digital_Mode_ConfigInterface in Digital Mode Config.vi of vdaq.dll returns 10403 as 17th arg (that must be error state) of the function when I run my application, however the part in the example sends out 0. Again I verified that al
l input parametes for the vi in both my application and the example are same. Any comments and recommandation will be appreciated.
Thank you,
the poor in trouble.
(3,279 Views)
Greetings,
That is very interesting. Could you post the VI that is generating the error so that I can examine the input parameters for DIO Config.vi?
Spencer S.
(3,279 Views)
