Digital I/O
Digital Trigger Vs Software Trigger.
Thank you! I'll give it a try!
Message 11 of 14
(3,006 Views)
Good luck with all of your work and take care!
Ian M.
Message 12 of 14
(3,005 Views)
In your snippet above: the write is outside the while loop, it that correct? And, what's the vi with the "?" and the digital waves inside the while loop?
Message 13 of 14
(2,990 Views)
The data being written is stored in a hardware buffer so it does not need to be in the while loop. The VI inside the while loop is a DAQmx Is Task Done.vi. Used to make sure the device is in a good state before exiting the while loop and clearing the task.
Ian M.
Message 14 of 14
(2,986 Views)
