Digital I/O
Digital output 9472 COM terminal- digital or analog ground?
Hello.
I am using NI crio  9012, chassis 9103, NI 9472 Digital Output and NI 9225 Analog Input modules.
Is the COM terminal of digital output module analog or digital ground? If it is a digital ground, should I connect the -ve of DC supply to 9472 directly to COM or should I place a capacitor or RC in between to separate analog and digital grounds?
I am connecting a 24V dc supply directly to the Vsup and COM of digital output module. Now the COM terminal of the digital oputput module will be analog ground or digital ground?
Please help me soon.
Thank You.
(4,841 Views)
The COM on the 9472 should connect directly to the ground of whatever it is the digital lines are going to.
(4,832 Views)
But to the Vsupply and COM terminals, I am giving a 10V dc voltage input through a regulated power supply module.This regulated power supply module is powered using a single phase ac voltage input, 230V. So now, since the negative of the RPS is analog, and as this analog -ve is given to COM terminal of NI 9227, wouldn't the COM terminal be an analog ground and not a digital gorund?
Thanks.
(4,788 Views)
