Digital I/O
Direct digital connection between 2 FPGAs
Is it okay to directly connect two FPGAs (in my case one NI PXI-7831R into one NI PXI-7811R) with a (SCSI-4?) cable between the front panel connector blocks. I am a little worried that some of the pins might have functions/voltages that can cause damage if they are directly connected.
(3,135 Views)
Independent NI sources tell me the answer is yes.
(3,133 Views)
