07-28-2005 03:29 AM
07-28-2005 08:38 AM
The 6528 has solid state relay outputs, meanning they they realy are switches. You get in the (-) pin what you put in the (+) pin if the switch is closed. The 60 V is the maximum voltage it can switch.
So it doesn't supply any voltage, it switch the voltage you connect there.
Hope this helps,
Paulo
