Digital I/O
Does NI DAQmx driver support PCI 6527 Card
In my application i am using PCI 6527 Isolated DIO Card. In the examples from LabVIEW 7.0, i refered the following VIs
1. Write Dig Chan.vi
2. Write Dig Port.vi
using DAQ 7 Driver.
There it gives a list of devices that can run these examples. The list does not contains PCI 6527.
Can I use DAQmx Example VIs with PCI 6527 Card?
Please suggest me what driver to use with 6527 Card (Traditional DAQ or DAQmx).
(4,583 Views)
Our DIO boards, including the NI 6527, are not yet supported by the NI-DAQmx 7.0 driver. This information is in the Knowledge Base article linked below, as well as in the NI-DAQ 7.0 Readme file.
Overview of Hardware and Software Support in NI-DAQmx
http://digital.ni.com/public.nsf/websearch/8DFD2C9085ACB5FC86256D2600817F77?OpenDocument
If you would like to use the NI 6527 in NI-DAQ 7.0 you will have to use the Traditional driver.
Best Regards,
Justin Britten
(4,583 Views)
Thanks Justin Britten.
(4,583 Views)
Hello partners,
I'm using NI DAQmx 9.7 in a machine hosting a Windows 7, but always when I tried to run the application I got this error.:
CAN'T LOCATE THE DRIVER ERROR 10240
Does you have any idea why could I'm facing this problem ? Previously I was using the original driver NI DAQ 7.4.4 (Legacy) in a machine hosting a Windows XP.
Other point perhaps here isn't the best place to start this new post, but I couldn't find how to post a new topic on the site.. My apologies, i'm waiting for any solution or advice
Best Regards
Josias Junior
(3,831 Views)
