Digital I/O
Does PCI6513 supports readback?
Does PCI6513 supports readback of channel values?
How do I find out if the channel readback is available for certain module?
(3,984 Views)
Accepted by topic author JaneGuo
Hi Jane,
The 6513 does not support read back. If you want to verify what you're writing to the digital ports, I would just wire it into a digital or analog input. Some of the high speed digital IO boards( 654x,655x,656x) might support what you're looking for. What is your application?
Sean
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
(3,966 Views)
