Digital I/O
Does anyone know about the DI continuos option with the DIO32HS card. My conputer alwaly freezes.
If anyone got an example program (Visual C) using the continuos option in reading(!!) from a device to the card I would be very thankful.
(3,649 Views)
The NI-DAQ driver ships with examples of doing continuous operations for Visual C.
Since you already have NI-DAQ installed you can launch NI-DAQ setup (Start-> National Instruments -> NI-DAQ -> NI-DAQ Setup), and it will give you an option to add/remove. Select to install support for Visual C and the examples will be installed in your NI-DAQ folder.
The examples that have "doubleBuf" in the title are examples of how to do continuous operations.
(3,649 Views)
