Digital I/O
Does the 7811r have the DATA ENABLE option?
I'm wondering if the PXI-7811r has the ability to tri-state its outputs? i'v tried to reset the FPGA I/O and i sometimes get the output at voltage level.
i've tried to use the Data Enable and write to the DIO and it seems to not function correctly...
can some one give me some form of answer or a quick labview program....
I've tried using the example but it seem it is used for the 7831r????
Thanks.,
(3,761 Views)
Hi CrukZ,
You can tri-state the output by changing the DIO line from an output to an input. Tri-stating the DIO line means to set it to high impedence, the DIO pin that's being tri-stated can take on any voltage value depending on the circuit it is connected to.
Stanley Hu
Applications Engineering
http://www.ni.com/support
(3,662 Views)
