Digital I/O
Does the NI 653x High Speed IO board exist in the PCI-104 Form factor?
I am using an embedded System (PCI-104 form factor) and I need this board in the same factor:
20 MHz (80 Mbytes/s) maximum
transfer rate
• 32 digital (5 V TTL/CMOS)
input/output lines
• 8, 16, or 32-bit transfers
• Start and stop triggering, pattern
and change detection
• NI-DAQ driver simplifies
configuration and I/O operations
Do you know if this is already designed for NI?? Any suggestions?
(3,239 Views)
No, it doesn't. National Instruments has only one device in the PC/104 form factor: the NI PC/104-GPIB board.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,237 Views)
