Digital I/O
Doubts about PCM-104 DIO96B Digital IO Board
Hello, I have these many problems which i could not get any answers from the manual or
from the data sheet.I have PCM-104 UIO96B board. so From where
i wi det its drivers? I have drivers of PCM-104 UIO48A DIO
board.SO whether UIO48A Drivers may work in DIO96B?
Once i will get Drivers then excect what should be the out
put of UIO96B DIO if i am giving only power supply to the
board.How to Do Jumper settings for Input/Output/Both modes?
What is the behavior(Output) of the board in different
modes? if i am giving any input to particular channel of the
board then what should be the output? If any one knows these
Answers please kindly Reply. I really have to solve this doubts.
(4,254 Views)
That's not an NI board. You will have to ask the manufacturer for the driver and how the board works. Have you heard of something called 'Google'?
(4,249 Views)
ohk
thank you......  Its not NI instrment its WINSYSTEMS instruments.
From google i searched a lot but i could ny find it.
thats why i out this question so if any one knows then they sil reply.
(4,228 Views)
From Google, I just did a search for 'PCM-104 UI096B'. The first result is your question. The second result is Winsystems. When you do a search, it helps if you specify some search terms that are meaningful.
(4,221 Views)
ya, i tried all dat i have its manual.
But i m not getting the thing  in that manual which i required.
so please reply if u know how to get the Base address of a perticular hardware  form C language Programming?
(4,209 Views)
As Dennis pointed out, the PCM-104 DIO96B board is not an NI board, however, the drivers are available on the following location: http://pc104.winsystems.com/products/PCM-UIO96B.cfm
Drivers for both Linux and Windows are available for download, so I don't think you'll need the UIO48A drivers anymore. As regards jumper settings and behaviour of the board to specific inputs, please refer to the manual again. I doubt if National Instruments can help you in that regard.
(4,187 Views)
