Digital I/O
Error -200077 occurred at Property Node DAQmx Timing (arg 1) in DAQmx Timing (Change Detection).vi:1
Whenever I run the attachment I get the error in the subject. I am trying to read a digital input change of state (0 to 1 - 1 to 0).
Instead, if I get read of the DAQtiming object, I get a memory dump, referring to this file: nimxdfk.dll.
Suggestions? thak you very much,
Davide
(3,823 Views)
Hi Davide,
which DAQ Devices are you using?
M
Matteo Brunella
Application Engineer
NI Italy
(3,816 Views)
