Digital I/O
Error 50405 at DAQmx write to USB-6501
Hello
Have a critical problem.
My company uses the NI USB-6501 OEM in the setup of one of our products. Won't go into what product it is but we have sold 4 of them since this summer and they are all stationed in Norway but far away from me..
After running for a few months at the end of september I got the error "-50405 DAQmx Write (Digital 1D Bool 1Chan 1Samp).vi:2<append> <B>Task Name: </B>_unnamedTask<0>" at one of the terminals. I logged in from a remote location and restartet the computer and got it running again. And since it has happened 5 more times... Three times at the same location and twice at another.
I have added the reset device to my system but that just gives the error "-200220 DAQmx Reset Device.vi:1<append> <B>Device Specified: </B>_unnamedTask<0> "
No USB-hub, No (un)plugging of other usb devices.
An USB - Serial adapter (UC232R-10) from FTDI is present on another port.
I'm trying to reproduce the error on an identical system right now but so far without luck..
Some of my code:
Any tips?
(5,278 Views)
My setup
Hardware:
 -Embedded Touch Computer
 -AFLMB-9652 Motherboard
 -Intel(R) 82801G (ICH7 Family) USB Universal Host Controller
Software:
 -WIN XP Embedded
 -Labview runtime 8.5
 -Measurement & Automation Explorer 4.6.2
 -NI-DAQmx Device Driver 9.1.1
 -NI-VISA 4.2
 -NI-VISA Runtime 4.2
(5,277 Views)
Hi.
This error is caused my loss of contact with the device. Based on your description I assume that you have read the following KB:
http://digital.ni.com/public.nsf/allkb/3EA2432762C45B298625734D0061D527?OpenDocument
There are several threads in our forum that discusses this issue. You can start out by looking at the link below, and follow the links that appears.
http://forums.ni.com/t5/Multifunction-DAQ/6009-USB-DAQmx-Read-Error-50405/m-p/1328551?requireLogin=F...
Hopefully this will help you identify and fix the problem.
-Tom
(5,208 Views)
