Digital I/O
Error while triggered input in PCI 6534
I am acquiring 32 bit data using PCI 6534.
I am running the vi buffered pattern input - triggered
port list 0:3
stop trigger is configured with pattern match
no of samples to acquire : 12
pre triggered points : 8
clock frequency 1 M
When i run this programm i got an exception error at digital buffer control. Why this happened? Same error is being repeated in the same situation.
If i am doing cont input i have defined start & stop trigger both . My acquisition starts on start trigger but how to stop the acquisition in vi because i need continuous data to read. What to do in vi block diagram after after trigger config
(3,200 Views)
Vishal,
What error are you receiving? From the information you have provided, it appears that you want to acquire data between a start and stop trigger. Is this correct? If so, you should examine the Start & Stop Trig Input.vi example. Otherwise, a detailed description of your application may be useful.
Good luck with your application.
Spencer S.
(3,200 Views)
