Digital I/O
External clock lvds ni 6587 basic connector clip
how to acquire external lvds clock on labview. I have used IO module clock 1 and connected to single cycle timed loop. In 40MHz timed loop i enabled the xpoint switch and set IOmodule clock 1 source to strobe bypass. I have also set the properties in Adaptor module settings. i am acquiring clock on stobe signals through SMA 2164 board.
Yet i am getting error that the host and fpga are not able to communicate. clock not detected.. the error which appears when clock is not being detected.
WHere am i wrong? need help
Message 1 of 1
(3,919 Views)
