Digital I/O
External reed relays
Hi, i have an easy question but it is just to clarify things. I want open and close, through 8 digital outputs of a PCI 6733, 8 external TTL reed relays connected to a SCB-68 . I would like to send arrays of digital signals to control the opening and closing of external relays. can i use a vi as that attachment? I only write an array of binary (0 and 1) and they will be interpreted as TTL output levels and so drive relays?
thanks in advance
(3,326 Views)
You should probably add a DAQmx timing function to control the interval between updates. Without one, I'm not sure what it will default to or whether you will get an error.
(3,321 Views)
I would also suggest to have a look to DAQmx examples for Digital Output (which you can find in LabVIEW Example Finder under Hardware Input and Output=> DAQmx=> Digital Generation) to have an example on how to generate digital data continously using a clock.
Hope this helps!
Licia
(3,306 Views)
