Digital I/O
Externally triggered acquisition with MHz rate
I am using PCI 6110 with signal applied to one of the analog inputs and ext. trigger applied at PFI0 input of the card. I am using sampling rate as 5MSPS (max.). Labview 2011 is being used in windows pc.
The pulse fed to the card (to read) is having 800kHz rep rate with 180ns duration, +/-2Vpp amplitude. So roughly I have 6.25 samples between two consecutive triggers. Since the signal is within 180ns, effectively only one sample (sample just after the trigger pulse) would have information about this signal. I want to read this one sample corresponding to each ext. trigger pulse and (without skipping) such 100000 points (so for 125ms with this rate) in one go.  The basic program I use to check it is shown in the attachment.  I can get two samples: one within the pulse and the other away from the pulse  using ""analog single channel multiple sample read.vi" " for one trigger.  The problem is how to read 100000 consecutive points???? One possibility was for/while loop, which I tried but found very slow. What I did was placed read.vi inside a loop and run the loop without wait VIs. But the iteration speed of loops was very slow (only few kHz), whereas a blank loop runs with a iteration speed of 10 MHz?  Also how can one synchronize loop iterations with  ext. trigger? How can I read/record 100000 or more such samples, each one obtaied from a ext. trigger pulse. Ofcourse, the display and processing could be done after the recording to optimize time.
Thank you in advance.
(5,836 Views)
kbgarur,
With S-Series devices like the PCI-6110 that you have, the native hardware re-triggerable functionality doesn't exist. You can perform software re-triggering which would involve stopping the DAQmx task and starting it again, this would be too slow for what you want to do. NI has a good document on Retriggerable Tasks in DAQmx.
Retriggerable Tasks in NI-DAQmx
http://www.ni.com/white-paper/5382/en/
You will need to use counters to achieve the re-triggerable functionality that you are looking for. Read through that document and there are a couple of links to example programs at the bottom of the link as well. Hope this helps.
Aaron W.
CLA, CTA and CPI
(5,739 Views)
Thank you Aaron!
As adviced by you, I am looking for such counter based possibilities now.
Cheers
(5,714 Views)
