Digital I/O
FP-file for NI-HSDIO
I am trying to use the NI-HSDIO as an IVI driver, but I cannot find the .fp file. The readme file says that the file is located in:
<IVIROOTDIR32>\Drivers\niHSDIO\niHSDIO.fp
but it is not there.
Does anyone know where I can find this file?
Thanks!
(5,491 Views)
On my computer, the .fp file is located at: C:\Program Files (x86)\IVI Foundation\IVI\Drivers\niHSDIO\niHSDIO.fp
But it seems like that's were you looked. Just double check because there isn't a fp file in the 64 bit program files directory. If you can't see it there, you might want to reinstall the HSDIO driver and verify that you are installing all the components you need.
Brian Morgan | NI Software Engineer, R&D
(5,486 Views)
