Digital I/O
Full range of NI 2900 USRP's DAC
I am working with NI USRP 2900 with GNU radio. I want to know the maximum amplitude (A) that can be set for the input signal "A sin(theta)" so that i does not get clipped by the DAC.  Can someone tell me what is the full range of its DAC (peak-to-peak) ?
(2,625 Views)
Hello Nachiket22,
When it comes to the parameters of radio stations, its output properties and capabilities then it's right to use terminology as output power, gain etc..
So there is no information about NI USRP 2900's DAC range.
In this case you can use mentioned parameters for your tasks.
__________________________________________
The best way to thank, is to give KUDOS
(1,988 Views)
