Digital I/O
Generate high precision frame
Hello to the community
I need help please for a new project to find a NI card
I need to generate frames with a period of 600us ± 1us (ie 1666.67Hz ± 2.7Hz)
I was thinking about a PCIe-6323
Problem is: counter accuracy is 50ppm of Base clock (100kHz) = 5Hz
Same for all the others boards I find, accuracy is 50ppm of a 100kHz Base clock...
Would you have any idea of material for this application ?
Cédric
(2,598 Views)
Accepted by topic author Programmer_
You're already fine.  Your error calc of 5 Hz does not apply univerally, it applies only to a 100 kHz signal.  The error is always proportional to the nominal, hence the ppm designation.
In your case, you need to be within 1 microsec out of 600.  1 part per 600 corresponds to 1667 ppm.   Your counters are *much* better than that.
So like I said, you're fine with the 6323 you've already got.
-Kevin P
(2,585 Views)
Ok I understand
The board must take the 100kHz and divide it by 60 (100kHz/60=1666.67Hz)
So the error 100.000 * 50/1.000.000 = 5Hz -> this number also has to be divided by 60
Thank you
(2,573 Views)
