Digital I/O
Generate signal from VBAI
Hi all,
I would like to generate a pulse signal from VBAI to Fatek PLC by using USB-6525. For my current VBAI program, the setting to generate signal is shown in the image below. It is necessary to put 200ms delay in between High and Low value in order for the signal generated reach to PLC. Otherwise, PLC won’t get signal from VBAI. Is there any other way to generate a pulse signal without Delay Step (where it makes a longer inspection time) in one inspection cycle?
Message 1 of 1
(1,061 Views)
