Digital I/O
HSDIO stream Gen & Acq simultaneously
is it possible to stream with HSDIO generating data and acquiring data simultaneously? I could barely stream continuously my generation data, and when I try to acquire data at the same time, I got errors. The error is either in generation session or acquisition session. I split the generation and acquisition in 2 different loops in main program.
Yan.
(5,543 Views)
Yes ,it can, but I cannot tell why error happens, since I don't see your code.
(5,531 Views)
Hi Kate,
thanks for your answer, I guess its just how bad I've programmed my application. I've tried to run both generation and acquisition in 2 different VI's and it works. Problem is there in my main program. I think I still need to learn much. Perhaps I'm using too much global variables as indicator in my subVI's which makes LabVIEW runs slower.
regards,
Yan.
(5,523 Views)
