Digital I/O
Help! Need advice on Data Read and Write functions
Hey guys,
                  I really need some advice or examples or pretty much any help I can find in trying to get these functions to perform correctly.  (these two functions are found within the main file) data_write is meant to read a spreadsheet file then write it to labview memory, or to memory with in the device it will later be hooked up to, and data_read is meant to read this memory, or what would be returned from the device, and then write that data into a new spreadsheet.  So at this point if it was able to create the same spreadsheet it initially read then it's working perfectly.  I'm on an insane time crunch and I would really appreciate any help especially examples to drag me out of this hole.  Thanks a ton.
Philip
(3,168 Views)
Duplicate
Ryan Verret
Product Marketing Engineer
Signal Generators
(3,150 Views)
