Digital I/O
High Speed Digital Output on AI level
I have an application that requires a VERY fast digital output in response to an analog input level.  Currently I am using a continious buffered analog input (Fs is high enough to capture the full signal contents and shape) and monitoring the max value of the aquired array and when the max value >= level I write a 0 the digitial line.  The problem is this is not fast enough.  I am familiar with starting a DAQ on an analog edge or digitial edge.  What I am wondering is if there is a way to trigger my digitial output when AI >= level in a way that is more reliant on hardware timing.  If more details are needed please let me know, any input would be appreciated, thank you
PCI-6221
Labview 7.1
(3,298 Views)
Hi Steve,
From the sound of your message you're right there and almost have the solution.  As you indicated if you use an analog read then it is going to take a bit of time between the acquisition of the data, pulling it into LabVIEW, analyzing the data, looking for a certain level, and then writing out a digital value.
What you need is some sort of triggering so that the operations you are doing are based off of hardware timing instead of software timing.
You are using an M-Series board, so in order to trigger your digital lines you will have to configure the clock for your operations to be one of the counter pins.  Once you have this 'external' clock source, you can then trigger that clock using a digital edge trigger.  Unfortunately the boards do not directly support analog triggering for the counter gates.
Probably the best thing you could do for this case is use an external Schmitt Trigger to turn your analog level into a TTL pulse.  You can then put that pulse into a PFI line which would be used as the trigger for your counter.  And that counter would be the timebase for your digital operation.
If you don't want to use a Schmitt Trigger then you will have to use a solution that uses software timing similar to what you currently have implemented.
(3,285 Views)
