Digital I/O
How can I plot real time data from an analog input module?
I have a ni 9225 input module that I am using with the cRIO 9014 controller. My module will only allow me to output data as a type double. Can someone help me figure out how to plot the data?
(3,334 Views)
Here is one method, only problem is long term acquisitions will run out of memory. In that case, you should either start deleting elements out of the waveform to keep it a constant size, or write data to a file. Example also posted in v2009.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(3,302 Views)
