Digital I/O
How could I simulate the output of a digital I/O device to test an application?
Hello everyone,
I have a general question. I am writing an application that is going to process the digital output of a PCI 6537.  At this moment I don't have access to the hardware. How can I simulate the output or even simpler, generate a digital waveform that can be used as the input of the application?
thank you,
Leily
Message Edited by 497 on 04-23-2010 08:13 AM
(3,236 Views)
Hey Leily,
You can create a DAQmx Task using Measurement and Automation Explorer.
Rightclick on Data Neighborhood -> create new -> DAQmx Task -> set your  Configuration
Now you can read this task with LabView using the VIs from the DAQmx dropdown menu.
Philipp
(3,192 Views)
