Digital I/O
How do I configure ports for PCI-1200 using LabWindows/CVI?
I want to use 2 ports of the PCI-1200 DIO ports as oup ports. Whenever I write to a port using WriteToDigitalPort, the other port will be reset.
Shoud I congigure the ports at the beginning of the program? If so How do I do it?
(LabWindows 5.5)
(3,410 Views)
I would suggest using the lower level NI-DAQ functions instead of the Easy I/O functions. (You have a lot more flexablity this way.) To configure seperate ports use the function DIG_Prt_Config, then instead of using WriteToDigitalPort, use DIG_OutPort. Here is an example that writes to one port using these NI-DAQ functions. All you need to do to write to two ports is add two lines in; another DIG_Prt_Config and another DIG_Out_Port.
Good luck and let me know if this does not work for you.
Brian
(3,410 Views)
