11-02-2006 08:59 AM
I
am using Measurement and Automation Explorer Version 3.1.1.3003 to view
pictures on a pc that are being sent from a video camera looking
through a microscope. The image I see in the viewfinder of the
microscope is MUCH smaller than the image that is displayed on the pc
screen. Looking through the viewfinder of the microscope, I can see
~20 mm across the object, but the display from the camera in NI-MAX
shows ~4.5 mm across the object. How can I change how much of an
object is displayed on the screen in NI-MAX? The camera is attached to the microscope with a camera adapter on the top of the microscope. The lenses the camera "looks" through and the lenses used when one looks through the viewfinder are the same, so theoretically, there should be no difference in what is displayed on the pc and what is seen through the viewfinder. We have ruled out the microscope and camera as the cause of the problem, which narrows it down to the NI-MAX software itself. I saw in the forums that you can zoom out on an image; however, this does not change the distance across an image that is seen, just makes the picture of the same ~4.5 mm across the object smaller in size. Any ideas or suggestions? | |||
11-02-2006 09:09 AM
