Digital I/O
How do I program Port C (4) as inputs on the 6025E using ComponentWorks & VB6?
When I drop the DIO Point control into my form and right click the properties window, Only Ports(0:3) are allowed. PortC is Port(4). 4 is not allowed!!
(3,406 Views)
Greetings,
Your board has 4 ports. You say you have access to Ports(0:3), which is port 0, port 1, port 2, and port 3. That is four. If you need access to the fourth port then you will reference Port(3) in VB. The issue is that VB indexes the array beginning with 0 and not 1.
Justin Britten
(3,406 Views)
Justin:
The PCI-6025E Board has Ports0=DIO<0:7>, Ports1=not available, Ports2=PortA<0:7>, Port3=PortB<0:7> and no Port4 for PortC<0:7> using ComponentWorks 2.01
Stanley
(3,406 Views)
