Digital I/O
How do you time a digital IO waveform with a Daq-Card 6024E
For some while I have a Daq-Card 6024E. I'm trieing to generate a digital waveform from the digital IO of the card. I can generate a digital waveform but the timing of the waveform isn't used for timing of the digital output. Thus the signal is processed as fast as posible by the Daq-Card. The problem and my question is how do I control the timing of the digital waveform with the Daq-Card?
(4,276 Views)
As the specs say, the timing of the digital I/O is software based so the output rate is going to depend on your code, the pc, the os, etc.
(4,269 Views)
The output rate is software based. But building an digital waveform and specifing the dt is setting your timing software based or is this a wrong conclusion? Or is the device incapible of setting timing to the digital output and it will always run at the speed the pc/os/code delivers the data to the device?
(4,258 Views)
For example: I want to update at 2khz. Setting an update rate in a while loop of for loop would make this imposible because the update rate of the loop and the daqmx code makes this imposible. If i trie to extend the waveform the updates between the data wil be at the maximum speed of the pc/os. The dt function of the waveform seems the be ignored. And the timing block of the Daqmx function always gives an error so I can't use that one.
The timing VI of Daqmx gives me constanly an error. Did I used the timing vi of daqmx wrong and if ive done that how should I use the timing VI?
(4,256 Views)
Accepted by topic author GJMABerends
If you want the dt to work and if you want to use the timing function, then you would need to buy a DAQ card with hardware timed digital I/O. The board you have simply has no circuitry to make use of the dt setting and DAQmx is smart enough to recognize that when you try to use a timing function.
(4,253 Views)
