Digital I/O
How to change state of LED to off after array is finished..tia sal2
Greetings All
I'm teaching myself Labview and have a question on a vi I'm working on.
I have a vi lopp through the array a set number of times and turn on and off 3 LED's the problem is that the Last LED remains on after the loop of the array is completed how can I end the loop with turning all LED's off.
Is this the best way to program this type of loop?
PS using labview 7.1 and usb-6008
TIA
(3,123 Views)
You could use local variables after the loop to make sure that all the LEDs are turned off. I added this to your VI to demonstrate.
-Alan A.
(3,114 Views)
