Digital I/O
How to configure 6533 both as input as well as output
I am using 6533 for acquiring data from the peripheral. I am recieving 16 bit data(so i am using port 0 and 1) . i am using pattern generation mode for acquiring the data.i am writing the application on vc++. Now i am required to use the one line in the remaining 16 bit(first bit of port 3) as output port. Can some one me how to configure the port in vc++. which API to be used DIG_grp_congif,DIG_prt_config??????
waiting for reply
praveen
(2,993 Views)
Hi Praveen,
You would want a combination of NI-DAQ function calls for input and for output. NI-DAQ ships with example programs for digital input and output for VC++ as long as you installed support for VC++ with your install of NI-DAQ.
You can do a repair on your install by going to Add/Remove Programs and adding the support from there. If you already have the support installed for it, you'll find your examples in the following directory: "C:\Program Files\National Instruments\NI-DAQ\Examples\VisualC".
The two examples you'll want to merge are:
1) DIdoubleBufPatternGen653x
2) DOdoubleBufPatternGen653x
Hope that helps. Have a good day.
Ron
(2,993 Views)
