07-12-2004
07:55 PM
- last edited on
11-27-2025
09:41 PM
by
Content Cleaner
Actually, I believe that this example is not compatible with the Base version of LV because some of the VIs being called dynamically contain subVIs that are not available in the Base version. Below, I have included a link to a VI Server example that you should be able to run:
Using VI Server to Call subVIs that Run Parallel and Independently of the Calling VI [broken link removed]
Spencer S.
08-06-2004 10:33 AM
08-11-2004
10:35 AM
- last edited on
11-27-2025
09:41 PM
by
Content Cleaner
Aaron,
The following KnowledgeBase details this process:
KnowledgeBase: How Do I Pass Data to Another VI Using an Invoke Node with VI Server?
Spencer S.
