Digital I/O
How to connect a mechanical switch to the USB-6009
sorry but I cannot open the attachment with the circuit diagram, I cannot open docx-files. Could you please attach a common file format, you attached a doc-file in another posting.
Message 11 of 17
(1,796 Views)
I hope this attachment can be opened.
Regards
Sufre
Message 12 of 17
(1,792 Views)
sorry but this attachment does not work either, I tried to open it with Word but it does not show up correctly.
Anyhow, you should check the voltage on the digital input with the LDR under light and in darkness (covered). The voltage for a high input should be above 2.8V and the voltage for a low input shcould be less than 0.8V.
Message 13 of 17
(1,790 Views)
I am sending a pdf file now, hope it works.
Kind regards
Sufre
Message 14 of 17
(1,783 Views)
OK now I can see your attachment.
At first glance there is nothing wrong with your setup.
What happens when you short (connect) the two output terminals? Since you (hopefully) use an open collector configuration this will just simulate an activated output transistor.
Message 15 of 17
(1,758 Views)
Wow, this is a great site. I mean yep, I also had the same problem in connecting the light sensor.
Gee, thanks for this great information. 🙂
Message 16 of 17
(1,714 Views)
Hi, Thanks a lot for your effort, its true there is nothing wrong with the circuit, it's just how the connection between the transistor output to the digital input.Smiley Happy
Kind regards
sufre
Message 17 of 17
(1,709 Views)
